When do you guys plan on supporting Forza Motorsport?
Forza Motorsport ?
I did an experiment today - launched Forza Horizon 5 (which leaves the motion listener app active in the background), then left it open and also launched Forza Motorsport. The motion worked.
I wouldn’t recommend it - it will either melt your pc, or give you terrible frame rate but I would guess it’s a fairly easy job for d-box to refine it and release the code.
D-Box should offer up a way for other games or developers to adapt this method built for previous Forza’s to titles that they do not currently support!
Forza Motorsport 8 Tested and works. Use simhub (https://www.simhubdash.com) to send the udp data to dbox at 32000 and click on the forza 7 in game center.
Hello! Don’t worry, it is in the works
We will support Forza Motorsport.
Just wondering, what does using Simhub in this setup? Currently I have FM8 configured to send udp data to D-Box at 32000 and it works, just wondering if I’m missing out on anything. Thanks!
Do you have an ETA?
With Simhub you can add wind fans and dashboards.
Is there way to get the motion from dbox and also the dash from Simhub.
I’m not sure how to do this.
Very very soon!
Is there anyway I can be notified via email or something that yall have added support for Forza Motorsport to D-BOX?
When you say you send data to D-box, what IP are you using? I have a gen1 Dbox, with the dongle (RJ45 to USB) but I don’t see any IP address anywhere. Thanks.
Hello Austin, you can follow us on our social media and we will post when we have new games in D-BOX. Here is ou handle: D-BOX Technologies | Longueuil, Quebec | Instagram
Your computer’s IP address.
Frederique - I think we may have a different understanding of “very very soon”
in the “forza” game settings… it should be (127.0.0.1) and (8000)
then “simhub” forza settings game telemetry udp port - (8000)
then under the settings it has “UDP forwarding”… set that to (32000) and ip address (127.0.0.1)
while game is running. launch the Forza button in dbox to receive the data.
yes you can get motion and it can show dashboards on different screens, add wind, transducers and shakers that rumble to all kinds of specific things like the each tires, or the actual engines, roads, ABS, pedals…
very easy to setup, and adds a lot more immersion.
Thankyou so much for that info. I will give it a try. Thanks.
Interestingly, Forza Motorsport 2023 was listed on the D-Box Games Catalogue page a couple of days ago, but was just removed today.
It’s out everyone! You can check it out in our catalogue: https://catalogue.d-box.com/en/video-games/3068311/
